Help! I have a noise coming from the rear nearside (KZ130 3L auto, 1994) which occurs once per wheel revolution; its a combination of whump-whump and mechanical graunching. Whatever it is can also be felt through the brake pedal. I've had both rear wheels & drums off; there's no sign of any cause, the bearings feel tight, the wheels turn freely & I can't feel any obvious diff gear damage by turning the wheels. I've also run the vehicle on jacks, when there's no sign of any noise similar to that heard when driving. The noise started 6 months ago & has been getting steadily worse to the point that something's going to go bang soon. Any suggestions on what it might be, or any tests that could help pinpoint the problem, or holes to peer into for clues?
My local garage has had the vehicle & can't find the problem. Any suggestions greatly appreciated; the most obvious cause would seem to be the differential, but then why does the noise appear to come from the nearside? I'm reluctant to start tearing it apart without being sure.
Thanks
Peter Hardcastle
Thanks
Peter Hardcastle
