I've been investigating a rattle over bumps and found that the drivers side output flange from the front diff has a fair amount of play, so looks like bearing has gone, does anyone know what these are like to change? from a quick call to milners and roughtrax it looks like a dealer part only too.
front diff output shaft bearings
thanks fella's, I'll keep checking then and check wheel bearings again (only had hubs off 6 weeks ago) front diff is dry no leaks whatsoever and that side output flange has about 2-3mm of play. Can't really hear the rattle until you drive with window open. thats the great thing about forums like these, the vast knowledge of experience owners.
