Just finished doing a first time inspection on our newly aquired surf.
changed the engine oil and filters no prob. got the spares from milners so thanks for that info. it all went smoothly. applied lots of coppercrest to the steering stops and cured that noise problem so thanks again. Only problem found was an oil leak coming from the oil pipe returning oil to the sump from the turbo. bit of a b*****d to do as the whole pipe needed to be changed. got one from milners again. otherwise car is excellent if a bit thirsty. thanks for all the helpful info. anybody on here from bristol area?
