the diesel pump on my 3 litre is doing strange things. the engine was from my previous hilux (rolled then never touched). i have fuel into the pump, fuel coming out the return but nothing going to the injectors. i have checked the powers to solenoids and all ok. the stop solenod under the pump is working, clicking can be heard yet still no fuel into the injector lines. the injector lines have been disconnected so i know its not them. timing is all good. any ideas, please help i want to drive my truck.
diesel pump issues
new development. with the 4 hollow studs (not sure their correct name) which connects the pump to the injector feed pipes taken out and all internals stripped out there is fuel comin out. yet with the internals put back in i have nothing coming out even after lots of cranking. what do those bits do they look like none return valves or pressure realease valves but not sure. not tried starting the truck as they are there for a good reason.
