Some months back I went to Ilfracombe to bring my sisters caravan back. While towing the atf temp light came and at roughly the same moment we overheated.
I stopped, had a look (we were on a hill so I couldnt check the atf level), couldnt see anything wrong.
Didnt want to chance it so called out the breakdown. Guy came and stuck a glass unit on the rad and proclaimed the head gasket had gone.????
Now I know the idiot was talking crap cos the liquid should of changed colour and didnt.
Upshot was we came home on the back of recovery truck many hours later.
Next day I topped up the water level, started her up & no probs even at normal runnig temp. No lights no nothing. While hot set handbrake, ran thru the gears and put her in drive. (Didnt go anywhere cos handbreak worked)!
Checked atf and no nothing not even on the dipstick!!! She was dry.
Spoke to a mechanic friend and we both concluded that was the original cause of the over heat.
Towing my own caravan the other day when atf temp light came on again. Pulled over immeadiatly, switched off engine and checked atf again. On the mark for hot this time. Got back in, started her up no atf temp light for rest of journey. Bugger did it again two days ago. Stopped, restarted no light!!!
Has anybody got a clue as to what is going on?
PS others might like to remember to check the atf cos that can easily be the cause of overheating.
