Tyre scrub & noise
  • Tyre scrub & noise
    I seem to be getting a certain degree of tyre scrub when taking right hand corners on full lock, dont know if its front or rear , left or right tyres. But last week when going up a multi story car park again on full right lock i got the scrubbing and a nasty graunching sound.... first thought was CV joint, but im not sure, any body else that could possibly shed a little light on this problem ??
    (ps... doesn't seem to do it all the time, have tried to recrate it but to no avail)
    Many thanks
    Many thanks
    have you greased your steering stops?
    Tony
      Done about a month ago, but will redo, but more concerned about tyre scrubbing
        Do you have an LSD? Some scrub is normal from the rears with an LSD.
          Dont believe i do have a LSD, how would i check just to be sure ?
          Fatfires....checked the stops and there all greased up, just thinking back i have had the stops grinding before and know it wasn't that sound
            not to sound sarcastic but surely u have a clue which corner its comin from?
              the worst it happened was in multi story, so its hard to determin which corner, other times it happened its only been for a second.... if any would believe fron off side
                I think a small amount of scrub is normal, the degree depends on the type of tyre and driving style. I wouldn't worry too much if your tyres aren't wearing unduly.
                Can you describe the grinding noise better?
                Re. LSD, check the axle code on the VIN plate.
                  check your tyre pressure and tracking
                  SWIFT AND BOLD
