Brain drain....been surfing for info on power steering pumps on 3.0l KZN130.
Is it just a case of undoing 2 bolts and pull it out backwards ?
All the bumpf i have just says "remove power steering pump" but not how too.
looks like a protruding shaft that obviously fits into some sort of gear that in turn rotates the shaft but is it just splined ?
I have a minor leak and i am not sure if it is the pump or just a split feed hose from the reservoir but thought i might as well gen up on whats in store.
Paul1566
Paul1566
