pipe near sump plug
  • pipe near sump plug
    hi, loosing a bit of oil from my knz185, took sump guards off yesterday cleaned everything and it looks like oil is dripping very slowly from small bore pipe near sump plug, is this an overflow pipe ?
    ANTZ
    Most possibly the overflow/run off pipe from the oil collector around the filter.
    This should only have oil dripping from it when you take filter off as the collector contains the spillage so it doesn't go everywhere.
      so does this mean i have problems?
      ANTZ
        not really, either its just old oil working its way down the pipe from the last oil change, or the filter seal is duff or even just the fliter not tight enough
          thanks, its going for a service next week so all filters being changed then.
          ANTZ
            Hi anthony, im in bradford, if you want me to take a quick look for you just let me know.
            SI.
              thanks for that , just had full service so see if that sorts it, got other probs now, put a new thread up. where abouts are you situated?
              ANTZ
