How hard is it to remove and fit a injection pump.
Fitting an injection pump 1KZ-TE engine
its harder to remove then re-fit it.Theres 2 bolts for the adjuster to remove and then theres3 bolts that hold the pump bracket to the block.
Once you got all the bolts out you will need to leave the pully nut in place and give the shaft a few good sharp hard hits with a hammer to release ithttps://www.facebook.com/groups/henpals/
