Harmonic Balancer
  • Harmonic Balancer
    Hi All
    My surf has developed a twittering noise when on idle or low revs.
    I don't think its the belts as they seem fine.
    I have looked on here and the Aussi Forum and the usual culprit is the Harmonic Balancer.
    A few people say that this a repairable item if not a bit hard to remove but my questions are as i look at the crank pully I can't see anything that looks rubber. do I have one on a KZN130 engine?
    also is it repairable or what is the most cost effective replacement?
    and what will happen if i do nothing?
    Steve
    Buy a replacement - quick
    Mine was twittering, by the time I changed it, it had chewed through the timing belt cover. Was lucky as a large peice of cover was nearly off and would have been big enough to damage timing belts.
    While the fronts off think abouth new water pump at the same time. I didn't and had to take it all apart again few weeks later
    ps the rubber bit isn't visible from the top, only when pully's off.
    My other cars a QUAD
    (sv1000spilot on surf forums)
      Erm
      I may be wrong but I thought the Harmonic Balancer was a 2.4 part, and didn't reside in the 3.0 litre.
      Trev
        Originally posted by UDTrev View Post
        Erm I may be wrong
        You are.
          Originally posted by NiftyNev View Post
          You are.
          In which case I sit corrected
            Harmonic Balancer
            Thanks for the info, but where is the best place to obtain a replacement?
            Thanks again
            Steve
              Last time this came up, it was declared that the 3.0 didn't have one....
              http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=52326
              Edit: Where is it on here?
              http://www.showmesome.info/hilux/inf...E/Page0160.htm
                Harmonic Balancer
                Well its back to the drawing board then.
                I will have to recheck the belts.
                you know what its like though, you look for a problem hoping its expensive like a £100+ pully then you find you don't have that type.
                I will give the bonnet a kiss when I get home
                Steve
                  They have a crankshaft pulley just like the 2.4 so why wouldn't it also be the same as a 2.4 and also act as a harmonic balancer. Without one the crankshaft would destroy itself.
                    Originally posted by Sancho View Post
                    EM-73 clearly shows a Crankshaft Pulley.
                      oh bugger?????????
                      We need someone with a 3.0ltr who has changed one.
                      I have emailed Roughtrax to ask if they do a pulley to fit.
                      I will post the reply when I get it
                      Steve
                        13408-67020 is the part number. Look here - http://www.google.com.au/url?sa=t&so...ZXPAWkLHc08MUA - at page 26 and the prado with the 1KZ-TE Engine and the HB1132-N which is the Harmonic Balancer for this engine.
                          I wasn't saying there was no crankshaft pulley, Nev, just that it has previously been stated that it's not got the harmonic balancer as in the the 2LTE (and that I couldn't find where it is in the engine manual). Your part number is correct
                          http://www.toyodiy.com/parts/p_J_199...JMGT_1301.html
                          The rubber is inside it by the way Steven.
                            Jesus, did you see the price for the pulley on that Aussie parts list? AU$393. That's extortionate!!
                            Mike G
                              I believe it's over £200 here.....
