Speedo n things
  • rodp
    replied
    Take the needle off and reposition it. Somebody has probably fitted a new face on it and made a cockup when refitting the needle. Is the pin for the needle to rest on, at 0, there or missing?
    I'll have to check in the daylight, thanks for the help so far folks, I'll be back
    Leave a comment:
  • MattF
    replied
    There's your problem then?
    Leave a comment:
  • RodLeach
    replied
    Hey Rod!
    Speedo is electronic on all but the early models mate.
    It may either be a sensor.. Wouldn't know which one im afraid. Or the needles been piŁŁed around.
    Correcting the needle is a simple but fiddley job.
    Leave a comment:
  • rodp
    replied
    Yep, but is it repairable / adjustable. Is the speedo electronic or cable?
    Leave a comment:
  • Albannach
    replied
    Originally posted by rodp View Post
    About 10mph !
    Leave a comment:
  • rodp
    replied
    About 10mph !
    Leave a comment:
  • MattF
    replied
    Does the needle start rising as soon as you start the vehicle moving, or just once you get to about 10 m.p.h?
    Leave a comment:
  • rodp
    replied
    Is the speed deficit even across the range?
    Seems to be but I've only been up to about 50mph so far.
    Is it cable or electric, at the moment I've checked nothing as it's dark when home.
    Leave a comment:
  • MattF
    replied
    Milners, Toyota or Roughtrax for parts. Breakers, (on here and scrapyards), for larger, more expensive items.
    Leave a comment:
  • rodp
    started a topic Speedo n things
    Speedo n things
    Well, I've finally got my Surf, for better or for worse. First morning of having it nearly ended in disaster, went round a corner in the frost that I had been around many times in the Defender and all of a sudden I'm driving sideways. That was the first lesson in not having permanent 4 wheel drive any more.
    Anyway, the real reason for this thread is that I need to sort out a few things with the Surf (yeah, I bought a cheap one that needs some tlc, I'm a cheapskate at heart)
    First thing is that the speedo works but reads slow, like it says 20mph but I must be doing 30+. Any clues from the experts please?
    I'm probably going to get a few parts to replace any worn / defunct items so is it best to just put a list in the wanted thread, does anyone read it?
    It's got a Philips carin navigation / radio fitted (not receiving due to broken leccy arial mast), bin it or keep it?
    Thanks in advance for any help.
    Rod
