When I turn on the ignition the timing belt light shows. It goes out as soon as the engine starts is this normal or does it need changing. The guy I bought the surf off says the belt has been changed but he cant find the recipt, is there any way to check if the belt has been done?
timing belt light
as long as the light goes out and stays out your okLast edited by stormforce; 8 February 2009, 14:15.https://www.facebook.com/groups/henpals/
Originally posted by NiftyNev View PostTB light on before starting engine is normal. No sure way of knowing if it has been done unless you do it yourself. BTW the T B light has nothing to do with diagnostics.
Nevhttps://www.facebook.com/groups/henpals/
