my surf has a rear fog light within the rear light cluster last year at the MOT station the mechanic said that i will need a seperate one due to it not being bright enough does anyone know the MOT requirements for the brightness/any issue with the fog light operationscheers
rear fog lights
Anyone know what the actual restrictions here are? We knocked the light off (pendulum type), and I bolted it back on directly to the back of the bumper instead, above where it was. Not exactly pretty, but it's functional. Will it be too high/in the wrong place now?Originally posted by nero279 View Postthere are restrictions on the maximum height, and also how close it can be to the other lights i believe.
If you have to go for a pendulum light just fit it as close to the O/S rear mud flap as possible.Andy
http://www.surfingafrica.net
Take a look at this http//:http://www.opsi.gov.uk/si/si1989/Uks...1796_en_16.htm if you read this and interprit it the same way I do you should not fail on how bright the light isI've taken a vow of poverty To anoy me send money
I didn't use any, I just sanded it to take the shine off wiped it over with cellulose thinners and sprayed with satin black Hammerite, two coats. The second coat should be applied thirty minutes after the first.Originally posted by blackpoolsparks View Postsorry off topic -
Vince
what kinda primer did you use on yur bumper?
Thanks for the link. I guess the 'Must bear an approval mark' covers that - you can't make your own unless you have it individually approved by whoever approves these things.Originally posted by Brummie View PostTake a look at this http//:http://www.opsi.gov.uk/si/si1989/Uks...1796_en_16.htm if you read this and interprit it the same way I do you should not fail on how bright the light is
This is more useful: It must be between 25cm and 1m off the ground, on or outside the centre-line of the vehicle, and at least 10cm away from any brake light.Andy
cheers for the replies lads looks like someone has converted my os reversing light to a fog light by painting the lense its all wired in nicely thought it was standard toyota its been pulled by mot tester for being pinkish and not bright enough i quoted the specs from the link on this thread and he said he will pass it if it is red so i will try repaint the lense
Or get a red bulb, done the same modification to my O/S light cluster.
Haven't had an issue yet, but MOT due next month so who knows
http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=47563Hold my beer and watch this
