How much tranny fluid for a KZN185?
  • How much tranny fluid for a KZN185?
    Better change my tranny fluid now its getting a bit brown, but cant find how much I need. I've searched a few dozen threads, but can't find any info.
    Also, i've checked ROUGHTRAX for a tranny filter and sump gasket, but there not listed. Any ideas or links to where I can get one please?
    Also Also, Is the Land Cruiser Colarado the same running gear as the KZN185? My mates got a Cruiser and it's almost identical to my surf. So I guess i could go into the local motor factors and get a filter and gasket of a Cruiser.
    Jon
    The filter is more of a strainer, it's a stainless steel mesh type in it's own housing which can be removed and washed with thinners or similar.
    The pan gasket can be cleaned/scraped off and replaced with RTV sealant. (gasket making silicone)
    To completely drain and re-fill the transmission you'll need 6.5 litres of ATF.
    The method is the same as this, but obviously when the passenger side is mentioned you read it as driver's side.
    http://www.lexls.com/tutorials/trans...anschange.html
    http://www.lexls.com/tutorials/trans...ransflush.html
