Starter Relay Location
  • Starter Relay Location
    Can somebody help me out and tell me where the starter relay is located on a 1994 KZN130? I cannot seem to find it.
    Thanks,
    -john
    hi jon.its on the inner wing if i remember rightly.if its not there then it will be under the dash on the right hand side but i'm certain its on one of the inner wings under the bonnet/hood
      Hmmm. Still no luck. I've removed the dash harness and the engine harness from my Surf as I'm converting a V6 pickup. I know the Surf ran because I started it, but for the life of me I can't find this silly relay.
      Any other ideas?
      Does anyone know if the big relay called "Self Timer Relay" that mounts near the main fuse box under the bonnet has anything to do with the starter circuit? I ask because it is in the area that some have said I should find the starter relay and it looks to have to correct wires going to it.
      -john
        Any of these help??
        http://forums.bauchan.org/portal/cad...tion=downloads
          The Surf wiring harness I'm installing in a V6 4Runner has the starter relay near the fuse/relay box under the hood, right hand fenderwell. Appearance wise it looks exactly like the glow plug relay.
          Michael
