can you turn off the passenger air bag on a 96 3rd gen surf dont no if this is poss
passenger air bag
Not to sure but the rule is that if there is no visable keyhole to switch the airbag off then no is the answer . Normally a switch offable airbag has a great red ring round it to highlight the fact .Originally posted by chizcan you turn off the passenger air bag on a 96 3rd gen surf dont no if this is poss
Only other way is to have the system disconnected at the airbag ECU but would require airbag ECU reset if required in future . If a vehicle has a airbag warning light the system has to work for the MOT . So if light not working and system disabled should be OK
RickRick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
[/CENTER]
