osram bulbs querie
  • osram bulbs querie
    hi
    ive just bought a set of osram H4 night breakers. they're 12v 55w, so im assuming i can fit them with no problems. but i just want to check that i wont damage the wiring lume.
    thanks
    jon
    oh its on a 3rd gen if that makes any differance.
    thanks jon
      If the Turd Gen takes H4 you will be fine (I had a 2nd gen, now bamboo powered )
      The Nightbreakers are brilliant
      Trev
        If you see smoke, the loom ain't upto it.
          They are only 55W so there should be no problems with the loom being unable to cope.
          Mike G
            55w is normally the "standard".
            Headlamp bulbs are twin filament 12v 60/55w the 60watt being high beam and 55 low beam.
            there should be no problem at all
              cheers, thanks for the help. its put my mind at ease
                JayC
                I've had osram nightbreakers (55W/60W) in my 3rd gen since last winter (a bit gutted how much I paid as you can get them for about £12 a pair now).
                No loom probs and they do work brill
                ta
                hawaii
