I have just discovered that the speedo arm is not sitting on the pin correctly on the speedo and starts about 5mm upwards. Giving a speed of about 7-8 miles more than you are doing.
Is it just a matter that the arm has been put on slightly high, when the face was changed and just needs to be reset
Reading past threads it mentions that it should just pull off, using a fork to pull it up. Is this correct?
Any advise on removing this greatly appreciated before I end up breaking it.
