waterpump and wheel bearings
  • waterpump and wheel bearings
    I have noticed water dripping from above the crank pully and after checking preivous threads this is an indication that the water pump is going, is this a striaght forward job as im going to replace the belts aswell has anyone got any instructions diagrams about set up the cam belt with regards to the timing marks and setting the tension
    Also im going to replace front discs and wheel bearings any info would be helpful
    cheers
    Andy
    Cambelt is very easy to do . Do a search on here and you find a couple of very well written articles by forum members on how to change the belt . I did mine in about 22 mins .
    Water pump should not prove to difficult either.
      Cheers mate will do
