Hi all this is the Mrs so please bear with me here
Our baby has experienced SAS since we loaded her up (full inside, 2 GSD's, toddler,roofbox, etc) and moved to Italy so now the back end visibly sits 2" lower than the front. What do I (ie: hubby) need to do to fix this? Is it as simple as changing the springs or would we need to get new shocks too?
Also been having problems with the oil. The husband checks it frequently before we drive off because of the heat over here and some days it seems to just disappear and then suddenly hey ho it's full or overfull again. What could be the cause of the disappearing act and what oil is suggested for use in hotter climates? It's still in the mid 30's here.
One more thing...our gators need replacing and the only parts place that will deliver to our BPFO is Milners are the "stick on" gators they sell any good or would it be better to buy those from Toyota? Language is an issue here so talking to a mechanic gets lots of head scratching and shoulder shrugging! Any help would be much appreciated
Our baby has experienced SAS since we loaded her up (full inside, 2 GSD's, toddler,roofbox, etc) and moved to Italy so now the back end visibly sits 2" lower than the front. What do I (ie: hubby) need to do to fix this? Is it as simple as changing the springs or would we need to get new shocks too? Also been having problems with the oil. The husband checks it frequently before we drive off because of the heat over here and some days it seems to just disappear and then suddenly hey ho it's full or overfull again. What could be the cause of the disappearing act and what oil is suggested for use in hotter climates? It's still in the mid 30's here.
