howdy partners,
so im probably the most clueless mechanic on the forum. just wanted to pick your brains on my recent over heating prob on my 3rd gen 3.0l intercooler
About a month ago i over heated i also noticed my air con wasnt working my fan belt had a bit of play in it so i had that tightened and fill the rad back up. air con working again, no overheating.
friday i was towing for about 2 hours when i over heated again. rad bone dry. doesnt seem to be any water in the oil.
After reading quite a few posts its seems a lot of people put the problem down to gunk in the rad. so should my next port of call be to flush the rad then monitor the temp and check the rad to see if she's losing water. Or am i totally of the mark ??!?
or B should i get her in to a knowable mechanic asap
all help is much appriecated
