Hi, my motor overheated yesterday on the motorway due to the radiator cap not being properly secured by the bloke i bought it off last week
, resulting in losing all the water somewhere on the M25. I noticed the temperature gauge was on the red and pulled over straight away.
I'm not sure how long i was driving with it on the red for before noticing the temperature, but it could have been up to about 20 mins. At about 80mph.....
After about 20 mins the highway officer bloke came along with water and i refilled when the needle on the temp guage was just above the halfway mark.
I let it cool a bit more and then drove for another half hour home and everything was fine. I'm just wondering if:
a) I need to change my oil now as it got cooked?
b) If there are any other things i should change or things i should now look out for or checks that i should make?
c) Is it likely that putting cold (room temp) water into a hot (temp guage halfway) engine would have buggered anything? (The highway bloke had to go and he needed his containers back so had to fill up there and then)
The car runs fine and temp is fine too. I know that the head can warp if overheated, but that doesn't seem to have happened, is there much else can be affected by overheating?
, resulting in losing all the water somewhere on the M25. I noticed the temperature gauge was on the red and pulled over straight away.I'm not sure how long i was driving with it on the red for before noticing the temperature, but it could have been up to about 20 mins. At about 80mph.....
, get your truck checked out sharpish.
