Hello everyone, only had my surf for the past year(3.0 td 130KZN) and love it, had a (sorry) 2.3td frontera before I saw the error of my ways, but been caravanning for 3 years.
The crappy vauxhall had no problem towing (until it died), lovley and steady, even up to 75-80mph,but since having the surf, I have been having problems.
As soon as you go over 50mph, it starts snaking, (truck seems a bit 'floaty' even on it's own) the loading is the same as when I had the frontera, nose weight is fine, I have tried different vans, with a couple of different stabilisers, still have the same problems. I have recently changed the rear springs for the 20% with a 2" lift from Roughtrax, a little better, but still not right
Could it be the shocks?, I have also tried tyre pressures from 30-55psi and still no good...any ideas?
The current 'van is an Elddis Crusader Superstorm twin axle, fitted with a winterhoff stabiliser, bit of a heavy bugger at 1600 empty 1900max - - - - -but nice hhmmmmmm!
cheers, any help would be great
disco now gone aswell
