Anybody know why my "O/D OFF" light has flashed all the way home? Gearbox working fine, including overdrive, and all gauges normal. Anyone help me?? Thanks!!
O/D OFF light flashing??
Thanks, both. Quick as ever. I have just had time to scan all the relevant threads, and noticed that others have had a speedo fault and a flashing O/D light occurring together. I should have mentioned my speedo has stopped working too. It seems from posts elsewhere this is what is causing the fault to be logged. I'll check the forum for dodgy speedo posts before troubling you all again. Doh!
'Twas a faulty speedo. The conversion chip wiring bullet connector was crimped onto the insulation, so the speedo worked erratically. Whenever it stopped working, a sharp clout got it going again for a while (like the missus). Followed posts on here to remove dashboard, remove crimped bullet and soldered wires. Everything is fine now.
