diffs
  • diffs
    Hi there just looking up on what oil to put in my front and rear diff and it goes on about LSD diff and standard diff i have never changed it so i take it that mine is standard.
    many thanks
    check transmission code on the ID plate on the truck (steel plate under the bonnet) If it ends in 5 then it's limited slip more info here http://www.off-road.com/trucks4x4/ar....jsp?id=274535
    Hold my beer and watch this
      thanks for that
        LS diff has LS marked on rear housing, well mine has!
        Yes! It's still in the garage. M1ROD
          As stated some are marked up via a sticker on the rear diffs, but the safest option is to look at the plate on the bulkhead for the codes mentioned.
          Gaz
