A.d.d Relay Location ?
  • A.d.d Relay Location ?
    MY NON FUNCTIONING 4WD SYSTEM IS REALLY BUGGING ME !!!!
    HAVING TESTED MANY THINGS AND AFTER READING MANY POSTS
    I AM CONFUSED AS TO THE LOCATION OF THE ADD RELAY ? SOME SAY
    IT IS UP BY THE STEERING COLUMN/BRAKE PEDAL MARKED AS A
    FUEL PUMP RELAY BUT MINE ISNT ?????
    COULD ANYONE POINT ME IN THE RIGHT DIRECTION TO WHERE ON EARTH
    AND MY TRUCK IS IT !!!
    MANT YHANKS JONNY
    MINES A LARGE ONE !!!
    On turd gens its behind the passenger side kick panel.
      Add Relay
      Had All That Out Yesterday ! Is It Called
      "computer 4wd Control" 89533-35080
        What was it i suggested when i saw you ! TonyN
          MANT YHANKS JONNY
          I thought you worked for Toyota.
            He does!
              Originally posted by marky View Post
              He does!
              No EPC?
              Workmates in the service bay not on speaking terms?
                John remember what i suggested you do when i was in Bracknell.
                Everybody wins
                  No EPC?
                  He gave them to me
                    No Epc !!!!!
                    WE HAVE A NEW EPC JUST LOADED ON OUR MAIN FRAME
                    BUT WE ONLY HAVE ENOUGH MEMORY FOR EUROPEAN VEHICLES
                    AT THE MOMENT ! AND NOT FOR JAP SPEC ONES
                    WE ARE CURRENTLY INSTALLING A NEW MAIN FRAME £££££££££££
                    SHOULD ALL BE WORKING SOON I HOPE !
                    MARK YOU ARE PROBABLY RIGHT I AM RUNNING OUT OF IDEAS !!!
                    HAVING NOW REPLACED THE ADD MAIN SOLENOID , THE VACUUM PIPES
                    THE FRONT DIFF SOLENOID AND VARIOUS OTHER BITS, BUT IF ANYONE
                    CAN TELL ME IF THE COMPUTER 4WD CONTROL IS THE ADD RELAY
                    THEN I WILL CHANGE THIS AND HOPE FOR SUCCESS (MINE DOES NOT-
                    CLICK OR ANYTHING)
                    THANKS
                      At least you can get Discount otherwise it would be expensive.
                        No No No
                        Just Looking At A Wiring Diagram It Lists A 4wd Ecu And A
                        Add Relay So I Am Guessing The Computer I Am Talking About
                        Is Infact The Ecu And Not The Add Relay
                        Confused . Com
                        Jonny
                          90987-03003 is the part number. It will be in a junction box very close to the 4WD control computer. Two relays together with the other being the spill valve relay.
                            John i have for these ecus and relays from the 2 x 3.0l breakers if your interested mate.Make me a sensible offer and i'll get them in the post for you
                              Its Not Their !!!!!!!!!! Where Is It !!!!!!!!!
                              Has Anybody Got A Picture Or Can Point Me
                              In The Right Direction As To Where The Add
                              Relay Is ? I Have Looked In The Passenger Foot-
                              Well Next To The 4wd Ecu And Nothing !
                              Up Under The Dash, Nothing !
                              Centre Console , Nothing !
                              I Have Diagrams From My Epc Which Say It Is With
                              The Fuel Spill Valve Relay In The Passenger Junction
                              Box ! Where Where Where !!!!!!!!
                              Help !!!!!!!!!!!!!!!!!!!!
