Viscous Fan Service In Depth
Not bad, good photos, but here in Australia it has been found that Toyota 10000cst silicone is the best for our climate, and 3 tubes should be the full dose. I adjusted the valves to begin opening at 70 degrees C and be fully open at abut 83 degrees C. Others have found 75 to be a better opening for their cars in our climate. By doing this, the fan locks in earlier and keeps the car cooler, however the down side is the use of more fuel and a little noisier. Also, now that my car runs cooler I find that it takes quite some more driving to get the temp up enough for the torque converter to lock in, so perhaps I use a little more fuel here too, but I run on B100 (biodiesel 100% - homemade), so it isn't an issue.
