hi - this is for a friend so details are a bit sketchy but any help would be really gratefully received
Symptoms
Both front calipers locked on - it was driven with siezed front brakes so discs are shagged - it looks like they got so hot they melted
Mechanic has taken the pads out of the calipers which will clamp on but will not withdraw when you take the foot off the brake with engine on or off - they will retract if the pressure is released through the bleed valve
rear brakes seem unafected
swapping over the master cylinder connections the rear brakes still function ok which would suggest not a master cylinder problem.
any suggestions guys ???
Kindest Regards,
alex
Symptoms
Kindest Regards,
alex
