I'm trying to take the head off my KZN130 and have removed most of the attached parts, but the rearmost (lower) nut holding the intake manifold seems completely inaccessible. It is covered by the loom, and a what looks like an exhaust recirc pipe running round the back of the head against the bulkhead. Any suggestions to remove all three of these would be gratefully received - I can feel a phone call to the scrap man comming on!
Head Removal Problem
http://www.hiluxsurf.co.uk/php_lib/v...at=1&submit=Go
Last one on the list, have a look at number 19!!
Good luck
http://www.apspropertyfix.co.uk/
Head removal update
Hi Guys
Sorry I was away a while. Many thanks for your guidance. I got the head off (with the manifolds) as you say - much easier. Sadly though the problem was a crack between the valves on two of the cylinders, so it's off to the scrappy for this motor. Thanks again for your help.
