can anyone tell me where exactly I bleed the coolant system on my SSR-X 3.0L
Or a picture would be great.
Thanks Nev.
best way to bleed it is start it up with the cap off, make sure the front and rear heaters are on hot position, unscrew the clip and pull the rubber pipe off the steel pipe coming out of the heater, when water starts coming out shove it back on and tighten it up, let it idle with the cap off a while, then put it back on
[size=5][/size]
