My trusty 3,ltr ssrx auto has just give me a big problem still wont, start turn key fires. idles, and dies, HEELLPP
has it had new filters...air,and fuel filters,if so you may have air in the fuel lines/injectors.Also put in some redex or atf to clean the fuel system a bit
all filters changed 3 months ago garage mechanic checked fault codes all ok he is stuck to
Sledge had the same thing on his 2.4 and TonyN found there was still air in the system.you need to slacken each injector and have someone turn the engine over to make sure all the air is out.
up untill the 21/12/07 i had been driving no problems then on the 21st i parked it on my drive after short drive from work 45mins later she was like this gutted
I had this problem after changing the fuel filter..It happened a few days later so i kinda suspected air in the system..On that occassion, it cleared itself..
However, on a diesel van i had, the firing and dying happened out of the blue..The AA guy was confident it was a "sucking air" problem, but even then it took him a while to find a small patch on a fuel line that had gone porous..It wasn't split, just thin enough to draw air..One pipe later and it was cured..
