I think my bronze bushes are dying.
Symptoms are:
Loose rattling sound from related area at 30mph and below. Possibly above 30 as well but maybe masked buy engine and tyre noise. Also does it in 4WD. When I had the t belt done I asked them to check the front-end workings to see if they could see anything worn. Everything appeared ok.
I understand there is an inner and an outer; should I have to replace them, is it advisable to replace both?
Chris
Symptoms are:
Chris
