Bronze Bush Virgin!
  • Bronze Bush Virgin!
    does anyone no part number of the big seal thats next to the inner
    bronze bush? also what grease should i use and do i put plenty on the inside of the
    bronze bush?
    also does anyone no the inside diameter of a NEW outer bronze bush?
    many thanks
    Steve.
    took a while but i found it in the end, does this help? http://www.hiluxsurf.co.uk/forums/sh...998#post349998
    =SOLD UP!=
      cheers, i red all that but do i have to grease the inside of the bush before putting back together? if so what grease do i use
        Use same grease as for ball joints and smear some on inside of each bush.
          I got the seal from toyota . it cost more than the bushes
          www.daemon4x4.org
            rite its all back together and i got the stub axle so i could just get washer & clip back on, is that right?
            as when lookin at the back of the hud the stub axle looks like its not in enough compaired to the one on drivers side!
            What wrong with it? tis doin me nut innnnn
