just took the 2 nuts out of thermo housing and it won,t move away........ideas please
thermostat
if you look thru the driverside wheel arch at the pipe from the rad to thermostat housing you will see there is a clamp holding the pipe in place also.Take the bolt out and then wriggle the thermostat housing till it comes loose.Make sure the thermostat is fitted the same way as the old one is fittedOriginally posted by hallyjust took the 2 nuts out of thermo housing and it won,t move away........ideas pleasehttps://www.facebook.com/groups/henpals/
Check this link, how to guide
Im sure also that theres 3 bolts and not 2 as you say.
Bogus
http://www.showmesome.info/hilux/wor...thermostat.htmСви можемо
you will find it tight to get off tho as its been on there for years probably but just be careful also when torquing the bolts up again that you don't over tighten and then snapOriginally posted by hallysorry bogus mine looks nothing like that (3.0 turbo diesel ssrx)https://www.facebook.com/groups/henpals/
