Been using wvo mix with derv, i get about 50 miles and my filter is clogging up , ecu is flagging code 14 . i filtered it 3 $$$$$$ times aswell , how can i drain the fuel tank easily with out fuss , is there a return to tank hose from the pump at all ????
i need this sorted for work monday morning , guys.
