i noticed roughtrax does the front anti roll bar bush kit, can someone confirm that the bushes in this kit do the small link arms also both sides . ???
front link arm bushes
yes. but dont bother trying to remove the link arms from the bar, you don't need to. just drop the nuts out the lower wish bone each side and push the bar upwards and then fit the new bushes, then do both the bushes on the bar, or vice verser, as long as you dissmantel 2 of the same leaving the others connected there is enough movment or flexation to do it in 20 minits easy. 14mm deep socket for the a.r.b link arm drop down nuts
