due to a cracked head i have fitted a genuine toyota head ,rad & cap, thermostat,
head bolt & gaskets, i have done 2500k and still loose water into the tank about a pint depends how i drive, i have towed and it does not over heat not even on a long journey from france.the rad stay cold at the bottom and looking into the rad cap i can`t see the water circulating , i can feel the water getting hot if i keep my finger in the rad so it must be circulating a bit.
i did not change the pump but what can go wrong with that as theres not a lot to it!!!!. any ideas.
