A few questions
  • A few questions
    Hi all, glad this place is back...was getting worried....
    firstly....
    1./ Im think of changing the rear coil springs for some of the +20% from milner, my question is how to you tell is the rear is sagging ?
    Is there reference points i can measure from ? all i can say is the the roof seems to be level front to back.
    2./ what is the maximum body lift you can put on a surf without having to anything else to it (ie brake lines , stering etc etc )
    3 ./ if i do put new coils on the rear i know i will have to crank the torsion bars to bring the front up level, i have read somewhere (not here) that if you crank them up it can greatly affect road handling quality (degrades it) and i would be much better getting upratded torsion bars. Is this true or false ?
    4./ where are the torsion bars and are they easy to crank up ?
    5./ Can you change the oil while the truck is not jacked up / on ramps easily ?
    See question 4 answer
    A 2" body lift is the max before having to do any mods
    I havent had any problems with mine and i have lifted mine by 5" altogether and thats 1.5" on the t/bars
    heres a link to show you what to do
    http://www.4x4wire.com/toyota/tech/torsion_bars/
    Yes you can.There is plenty of room underneath to be able to get to the drain plug with lifting it
    __________________
