Hi everyone, whilst driving to work the other day i arrived to find oil gushing out of the bottom of my sump. After cleaning it away my freind suggested that it was the "casting hole" a small semicircular hole in the bottom of the sump. Does this sound correct? he said there shoulld be a bung in there to stop the hole, if so where is the best place to order one? any help at all is appreciated. I drive a 3.0 Ltr SSx import.
Massive oil leak!!!
The only hole on the sump is the oil drain, the sump is pressed steel not cast anyway!
If its not the drain bolt fallen out, then you've hit something thats pierced a hole in the sump.
Got pics?4x4toys.co.uk - Keeping you on and off the road...
Thanks for the input guys, as you can prob tell im a noob with engines! I havent done anything that i think would crack the sump but i spoke to a fellow surf owner at the pub, and he suggested that it coulb be the sump gasket? ill try to get some piccys for you. i appreciate the help!
but tonys got a thing about oil.well his eyes have anyway.Originally posted by truckarmsTypical TonyN,
Any destruction/ serious damage and you want photos of it!
