Thanks for the help in the boiling over thread guys. Well I have finally got a day off and I am going to tackle the Surf. I have got my new rad cap which a few of you thought could be part of the problem.
The thermostat in the Surf is one that keeps it running cooler, temp gauge just under a third, and the standard one which has the temp gauge just under half when warm as a spare. Is the cooler one okay to keep in?
I currently have the car parked on my drive with the front end at the highest point. The coolant level is just below minimum in the expansion tank, about an inch and a half or so and I can't see any in the radiator. I take it that to burp the system I should remove the old rad cap and start the car and as she is idling set both heaters to hot and turn them on to full blast and slowly top the coolant up through the rad.
Here are my really stupid questions so apologies in advance. How will I know if and when the air is out of the system and do I start topping up the coolant straight away and I take it I fill it until she is just below the expansion hose at the top of the rad and do I leave the rad cap off for a while after doing this. Do I then need to top up the expansion tank to the low level as it is just below it. Finally does taking the radiator cap off to check the level allow air to get back in the system or break the vacuum. Forgive my ignorance as a few mechanics have been leading me up the garden path and giving me contradicting information.
