Can any one tell me how to remove the door panels front and rear to access the speakers on a kzn185 without breaking any of the pins holding them on. I have tried searching the faqs but came up with nothing , thanks
Removing door panels
The simple answer is - " You can't remove the door panels without breaking any pins." lol
To give yourself a sporting chance you need to make a door card removing tool. Its a bit like a two-pronged fork which you slip behind the door panel with one prong either side of the clip. Gently easing the clip away should aid removal without breaking, but remember, this is old and brittle plastic so be prepared for some breakages.
Hope this helps.Keith
