I have done a search and found a few threads on this but I wonder if any of you can please just tell me how to remove the hub to get to the studs.
It is the KZ185 with sealed wheel bearings so I was wondering how to do the job?
Broke one of the studs on the front after replacing discs and pads.
Can it not be done by removing the disc and backing plate giving access to the studs?
Thanks for any help, at least I cured the brake judder!!
Pete.
Pete.
