Light on Panel
  • Light on Panel
    I have a Hilux surf 1995 3.0 Diesel and recently I am seeing an orange light on my panel, when I started the engine the ligth appear, but soon disappear then five minutes later its appear again when I keep the speed in the minimum, but when I push the aceleator the ligth gone. Can anybody helpme?
    I attach the pictures about the light. I really apreciate your help,
    Best regards for all,
    Wilmer
    Check the oil
      Originally posted by The Hornet
      Check the oil
      The oil level its good, another sugestion!
        You need to read the fault codes to find out what the problem is, this page will help you sort that bit.
        http://www.auto-diagnostic-codes.com/
          can be a number of things that light is just telling you there is a fault you really net to have some check it out with a fault reader to find the problem this is usally the quickest way
            Does any have a pdf manual repair? You know for diagnostique when we hear an engine noise or when we see an alarm in the panel.
            Thanks for all your comments!
              I canīt find any diagnostic code for this alarm.
                Have you followed the procedure as listed on that site.
                Also read this. http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=24654
                  Try this link and go to the diagnostics section of the manual.
                  http://www.showmesome.info/hilux/info/manuals/1KZ-TE/
                  Nev
