Hi there,
i'm after some advice please. I have a '94' 3.0 kzn130 surf. Recently it has started puffing white smoke and missfiring slightly when starting, it also seems a lot worse when switched off for 5mins then started again (people disappear in the smoke)! It is also loosing water. There is no sign of oil in the water or water in the oil. On tick over with the rad cap off it does bubble though. Also the main feed that comes in for the glow plug's, when i hold a tester on it.. it just flick's up and straight back down again. I've popped a couple of plugs out and they light up fine. I've tried a different glow plug relay and that made no difference. Any advice would be much appreciated. Cheers.
Fingers crossed it won't be that serious. Thanks again, Claire.
or the Connuba inn
