wishbone
  • wishbone
    changed me top wishbones the other day. was quite easy apart from the bar what slides into it and is bolted undernieth about halfway down surf does anyone now what its for and how tight i should fasten it up.
    cheers all
    cheers all
    that will be the torsion bar for your front suspension.you will need to let the surf settle and then measure the distance from the wheel rim to the wheel arch on the opposite side and then adjust the bolt on the oter side to level the front end up
      http://www.4x4wire.com/toyota/tech/torsion_bars/
      this will show how to adjust the torsion bars
        cheers will go and have a look now. main thing is its not something i have f----d up
          when you adjust the t/bar mark the bolt and frame so you know how many turns you have done
            cheers
