ATF fluid level
  • ATF fluid level
    I'm not sure what's going on in my gearbox!
    I drained and replaced the ATF fluid yesterday. Went for a spin, did the through the gears bit and tested the level, it was a bit low so added some more. Quick spin, through gears test again and just at the top of hot. Fine I thought. I checked the level both times on the flat.
    I tested it again this morning cold, and its way above the hot mark??? My drive is on a slight slope though (bum down). Just off to get it warm and see if its at the right place when hot.
    Bizarre though. Ideas please?
    Dave
    Some persistence with the search facility has paid off.
    Answer here,
    http://www.hiluxsurf.co.uk/forums/sh...light=ATF+high
    Dave
