Vac/Valve
  • Vac/Valve
    Can anyone say what this is and where can i get a new or 2nd hand one from As you can see iv snapped 1 of the plastic nipples off tryed glue no joy
    Advise please.
    Send this guy a PM or Email, he might sell you the part.
    http://www.hiluxsurf.co.uk/forums/sh...ght=interested
      I assume this is the one for the EGR. If it is and you have blocked the vacuum hose to the EGR then block the remaining hose on the valve to prevent vacuum loss. You can then leave it as is or replace when you find another. The remaining hose on the valve is for vacuum supply. The valve will still be switching as you are driving and because the other connection is broken air will be sucked in through the valve reducing the amount of vacuum to other components that need it.
      Nev
        I've got one, give me a call and we'll sort something out.
