Hi guys, I havent posted much since I joined because my 3.0 Surf lasted one day before I realised the head was knackered and it then took 6 months to get it back on the road again (a long story I won't go into)
Anyways I've had her running with the new head now for about a month, and until a few days ago all was tickedy boo.
But the other day I noticed the check engine light come on for a few seconds, at almost the same time the temp gauge dropped from the middle to the cold position, where it stayed for a little while before jumping back up to the middle.
I was on the A14 at the time so I had to wait for a Layby to pull over and check everything was ok with the coolant system. So I wacked both the heaters up to hot (which they both did fine) and then pulled over.
I couldn't see anything wrong and by now the temp gauge was back in the middle again so I continued, with the heaters on full hot just in case.
The gauge dropped to cold a few times and the check engine light flashed on a few times but I made it to my destination no problems. When it had cooled down I took another look under the bonnet, the coolant was to the top of the rad and the header tank was full so to be honest I started suspecting a fault with the gauge or the temp sender.
On the way back the gauge didn't move at all from the middle and the check engine light stayed off for the whole trip back (about 60 miles). Anyways this morning the gauge dropped to 'cold' and has stayed there throughout the whole day.
Does this sound like a faulty or loose temp sender? Or a faulty gauge? Both heaters are still blowing hot and as far as i can tell there's no sign of overheating.
I'm just paranoid because the last time I saw that check engine light it cost £1500 and she was off the road for 6 months
Showed absolutely no symptoms till I blew the radweld out with redex and a heavy foot on day one.
