Bleeding the water system
  • Bleeding the water system
    Hi Lads/ladets
    Have just fitted new head to 3.0ltr td 3rd gen.1996
    Now if i have to, how do you bleed the water system as iv never had to do this TONYN.Where are you i is gona need help with this one.
    all advise please......
    Originally posted by welshsurf
    Hi Lads/ladets
    Just run the engine with the rad cap off and the heaters set to hot and just keep topping up till it takes no more. Switch off, let cool and re-check level top if necessary then re-fit rad cap.
      Hey,Thanks bushwhacker its that simple hey......Thanks
