Originally posted by TonyN
COMPRESSOR SURGE - Compressor surge occurs when the throttle is slammed shut and air is caught between a pumping turbo and the throttle plate. This air blasts its way backward out the front of the turbo. When this happens, there is suddenly room for more air in the manifold, and air is pumped back in by the still-spinning turbo. The throttle is still closed, so the air again blasts back out through the turbo. This continues until the turbo loses enough speed for leak back around the compressor to dampen the air oscillations. Compressor surge can also occur under boost if too much boost pressure is present with low airflow through the system. The chirping sound heard from the turbo when lifting off the throttle while operating under boost results from this oscillating air volume. This noise is suppressed by the bypass valve.
I'm just curious, is all.
![Smilie](https://hiluxsurf.co.uk/core/images/smilies/smile.png)
Ta, Paul.
